By using this extension you will be able to change frontend customer address fields and make them required/optional/hidden as you needed. Demo: https://demo.soft-php.com/joocart-extensions/ Address fields will be changed in checkout->register,guest,payment address,shipping address and account->address->add,edit page Installation 1.Install this extension(change_address_fields_3.x.ocmod.zip) from OpenCart admin panel: Extensions->Installer 2.Enable and refresh from OpenCart admin panel: Extensions->Modifications 3.Go to Extensions->Extensions->Modules, then install ,edit and enable Change address fields(Required/Optional/Hidden). Check your required fields and hidden fields there and save. 4. Done
🪄Enhance your site's user experience instantly by customizing address fields to match your needs perfectly—boost conversions and reduce form abandonment now.
